HAL.Port.OpticNotCompatPortType
Description
An optic module of a particular type has been inserted into a port of a type with which it is not compatible. The optic module can not and will not work in the specific port.
Remedy
Remove the incompatible optic from the port and replace it with one that is supported in that port.
Severity
Warning
Message Text
The %optic% optic module is not compatible with %portType% ports - please remove it from port %slotPort%.
Message Parameters
Name Type
optic String
slotPort SlotPort
portType String
Applicable Platforms
